Cams Module
flexcon-cams v17.0.zip
This module permits to place cameras in the model and so to follow an object using the nearest camera.
How to install it:
- put the "Cams Module" folder into the Flexsim "modules" folder
- run Flexsim
This module adds:
- the "Camera"object into the "Visual" section of the Flexsim standard library
- "Cams" menu button
How to use it:
- insert cameras into your model where you want and adjust z locations (it's not important where camera is looking)
- highlight the object (maily a task executer) you want to follow
- click on the Cams menu voice: "Set Cam focus to highlighted"
- click on the Cams menu voice: "Camera activate"
- run the model
- the nearest camera to the focused object follows it
- click on the Cams menu voice: "Hide Cams and Camera Manager" to hide or unhide cameras
Example:
