FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
AGV Template Process Flows for 16.1
[ FlexSim 16.1.0 ]
Attached is an example model that uses both of the new template process flows for AGV and AGV elevator control, available in FlexSim 2016 Update 1. Thanks @Katharina Albert (I believe), who provided the seed model, which I adjusted/extended as I implemented these process flows.
This model enumerates many of the control point connections and path configurations you might use in an AGV model when using these template process flows.
