FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
3D Flow Mapper
The attached model contains functionality to depict the item flow as a 3D map using a FlowMapper3D Object (cylinder) and an associated Object Process Flow.
Additionally a 'kpi' label on the object gives an indication of layout performance to which you can link and observe as you interact/experiment on the layout.
To set this up in your model you'll need to add a Group of objects whose entry events will be used by the mapper - calling that Group "FlowMapperObjects". Then you'll need to add a ColorPalette called "HeatPalette". Finally you'll want to copy the FlowMapper3D object and the FlowMapperProcess to your model.
Note that there is a boolean label 'showPercents' on the FlowMapper3D object to tell it whether to show percentage text or the number of flowitems for each location pair.
3DFlowMapper.fsm
Comments
Hi Jason,Model is showing this exception.
time: 36.199861 exception: FlexScript exception: Label property totalTrips retrieved on /FlowMapper3D. Label does not exist. at MODEL:/Tools/ProcessFlow/FlowMapperProcess/UpdateMaps>variables/codeNode at line 10
Thanks Arun - I thought I'd checked my last minute changes - I've re-uploaded the model with the fix.
