Reverse runtime to create a pull system
I would like to suggest a new dev on flexsim regarding the ability to run on reverse the simulation to be able to create pull system based on a demand table.
For example, based on a set of departures, I would like to know when the material should arrive and when the fabrication might start to be able to fullfil the departure schedule.
That, with a reverse option of the runtime would give me the possibility to run as usual or on reverse depending on the scenario.
Best regards,
4 Comments
If you optimize a model by Optquest to aim for a exact stay time, you get your desired result in a classic forward approach.
If you build the reverse process - the result just falls out - no optimisation required. The missing part is having the model datetime calendar work backwards while the event time continues forward.
patrickABAWF
I have built a model of a factory which operates in Pull logic starting from the schedule of trucks who come to pick up finished goods. I used the standard FlexSim logic except that the flow is controlled by ROPs (re-order points) and ROQs (re-order quantities) so products only flow to the next step when they are required (or authorized) to do so.
I have recently created this video overview of the model:
Link to video of a model
You can do this yourself, just model the process in reverse and record all the events as the model startdatetime -time (where the start datetime is actually your completion date/time)
