Quality - Parameter enhancement
Currently, you may only enter 1 numerical data point for each parameter.  Need to be able to add more than one numerical value for a parameter.  For instance, we measure 9 points on part, lets call it plate thickness.  Currently, can only enter "5" (mm) as a numerical entry.  Yes, we could enter it as text and put 5mm, 6mm, 5mm, 5.25mm, etc... but as a character string which makes statistical analysis not readily accomplished.  If there we the ability to capture 9 (as an example) numerical datapoints, i.e. Top left 5, top middle 5.5, top right 6, etc... then we could capture the data with 1 parameter (plate thickness composite) and could perform statical analysis on the data.
1 Comment
philboboADSK
Use the Option parameter type to specify different available options for a parameter. See: FlexSim 2027 Help | Model Parameters | Autodesk
If you want nine parameters, just use nine parameters (i.e. "Top left", "top middle", "top right", etc.). Why do you want all nine parameters to have to be one parameter?
Parameters are grouped into multiple Parameter Tables. You could put those nine parameters into a "plate thickness composite" parameter table.
