Possible Bug with combiner 25.1.3
it the attached model, the combiner called Processor is to combine one item and one tote.  When the cycle time for the combiner is a fixed value, it works fine.  However when the process time is a distribution,  (i have tried several) i get the following error.
time: 76579.103677 exception: Exception Caught in Combiner::onTimerEvent(treenode involved, int code, char *datastr) object: /Processing
time: 76579.103677 exception: Exception Caught in ObjectFunction246__project_library_FlexSimObject_behaviour_eventfunctions_OnTimerEvent object: /Processing class: /Processing
time: 76579.103677 exception: Exception caught in TreeNode::receivemessage()
time: 76579.103677 exception: Exception caught in Executive::processeventinlist().
Just before this time, the combiner brought in two items, it then goes into a blocked state,  still processes, and then back to normal operation until the next error message.
I am not able to repeat this error, in any other model,
Dhuey
2 Comments
Jeanette_Fullmer
Hello @dhuey_cronk,
I am not seeing this exception when I run your model. Did you upload the correct model with the issue? Is there anything I need to change to the model? The combiner in question, is it the once called processing attached to sink24?
hmm, if you use your table, then many values are stings. A string can consists of an executable code, BUT you need to reference the cell by a command or method that evaluates a string as a code and not just read the string value.
reading a cell value directly like a string as a number
