One button that functions as a toggle between Run and Stop
Avoid having to move the mouse cursor between the Run and Stop buttons.
3 Comments
This is not doable. Once a model is stopped any other action from a dashboard is not evaluated any more, because the model is not runnung.
A Stop suspends any code execution from the model. An external action is needed to resume a model run.
Try it with code snippet
applicationcommand("run")
to get a model run by hitting a dashboard button.
Here is an code example for a dashboard button. Edit mode must be deactivated to fulfill action.
treenode link = node("..>objectfocus+", c);
runstop++; // increment a global variable or any other available label, node value or a table cell,..
if (runstop%2) /* modulus operator to get values of 0 as false or 1 as true*/
applicationcommand("run"); //true evaluated as run
else applicationcommand("stop"); // false as stop
runstop is a global variable in this code. Start value is set to 0.
toggle_run_stop_dashboard_button.fsm
You can use CTRL+Space to do this without using the mouse:
hong_seongweon
Thank you very much for the help
