Match event parameters by value
It would be very useful if the Wait For Event and Event-Triggered Source activities allow matching an event trigger parameter by constant value, rather than by label.
For example, suppose I want to wait for an item to enter through port two in a Wait For Event. At the moment, I have to create an Assign Labels activity that creates a label "port", set it to 2, then in the Wait For Event I can "match" the Input Port to the label.
It would be pretty cool if instead of just a "match (label)" option, there is also a "match value" option so I can just type in "2" into the first column and select "match value" from the second column. Or maybe even better: change the first column into a Universal Edit where one can either put "Label: xxx" or type an expression. This even allows use of global macros such as MY_OBJECT_OUTPUT_PORT.
Using an Event-Triggered Source, it's even a bit more complicated: before the token is created it has no labels, so I have to create a token for all entry events, grab the input port to a label, and then Decide whether to keep them or throw them right into a sink.
There it would also be nice to have a similar setup to the Wait For Event option, but with only the "assign" and "match value" options and of course not "match label" and "insert at front".
2 Comments
What is going to happen if the event itself is set into a list and is dynamically evaluated. Can we evaluate the change of the value in any kind to create an event to look for like watch a variable? Would such an approach work with a back order, too?
JordanLJohnson
This is possible in version 2018 Update 1. You can use the Match Value option, and put the value directly in the activity.
