Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Duplicate Option In Parameters and Performance Measures
Hi Flexsimmers,
In the parameters table, we don't have a duplicate option. So if I want to create more number of parameters of the same type which have an only difference in the name. I can easily do it using the duplicate option if it was available. Now, I we have to manually enter and change the parameter type and other details, which is not easy. This feature is already available in statistics collector, groups etc.
Arun KR
4 Comments
FelixMoehlmann
This sounds like a good idea. But for the moment, just in case you are unaware: You can use ctrl-c/ctrl-v to copy the settings in the value column as long as you only select a single cell at a time.
arunTTT2P
Thanks @Felix Möhlmann. I'm aware of this.
@Arun Kr This feature was added in 23.2. The 23.2 beta is available now for download.
arunTTT2P
