decimal precision
decimal precision
You can set the decimal precision from the user interface. It is 2 by default. I do understand that the precision is used when the decimal numbers are shown in the UI. But why precision is also used when calculating something in FlexScript code? I'd like to have as accurate decimal numbers as possible when calculating something but when showing at UI, the precision is ok.
5 Comments
The decimal precision is full for all calculations - the model settings option is purely for display.
tomi_kosunen
So it seems to be. Thanks. I had some troubles with my model and obviously I did wrong speculations where the error lies.
No problem - I think I was guilty of doing exactly the same thing many years ago.
Jeanette_Fullmer
The decimal precision can be changed in the Model Settings.
Jeanette_Fullmer
