Custom location for installation
Hi
I would like to install FlexSim at a different location other than the default folder. Though I can browse to that location, but the system did not provide an installation folder such as FlexSim 2016. I can't change anything on the installation line at the GUI so I need to create a folder manually than I point to that folder.
Could the developer take a look at the installation GUI to allow use to create the installation folder at the installation GUI instead of creating it manually?
David Chan
3 Comments
adrian_haws
@david.chan This has been placed in the Development space instead of Help since it relates more to future FlexSim development than it does to technical support.
philboboADSK
When you browse for a custom directory, there is a Make New Folder button at the bottom left corner of the Browse For Folder window.
chanykE2WUT
@phil.bobo
Thanks for your information.
After choosing the drive I would like to install, the installation directory is not shown in the path. I could not add. So I will need to create a installation directory for that purpose. Though small matter, but having the name of the directory helps.
David
