Bug on Experimenter
Bug on Experimenter
  1. Experimenter makes an error when the model doesn’t have any Performance Measure. And it also doesn’t make a report in a proper way. I think some users might want to use the Experimenter without Performance Measures. I attached the model and the report (NoPerformanceMeasures.fsm & NoPerformanceMeasures.html). The error message is as follows.
    1. exception: FlexScript exception: invalid index at VIEW:/active/PerformanceMeasures2670052476/tabcontrol/PerformanceMeasures/SelectPFM>eventfunctions/OnSelect at line 15 c: VIEW:/active/PerformanceMeasures2670052476/tabcontrol/PerformanceMeasures/SelectPFM
  2. Experimenter makes an error when a report is generated with Empty Graph. In the attached model (EmptyGraph.fsm), a graph [State] refers to a group [Worker] which has no member. The report file makes an error when I click button [Add Chart] to check the empty graph (EmptyGraph.html). The error message is as follows.
    1. Error: TypeError Cannot read properties of undefined (reading 'settings') Callstack: function initializeChart(div, properties, redraw, callback) function(element, data) function addDashboardChart() function onclick(event)
  3. I have attached files as a compressed file.
  4. Flexsim version is 24.1
1 Comment
Jeanette_Fullmer
Status changed to: Under Review
Hello @wooram_kim,
I have verified the first issue in the version 2026, and I have submitted this to the development team for further investigation.
The second issue is not reproduceable in FlexSim 2026.
