Add an option to change multiple replicate OptQuest results to use median instead of average
Currently, when OptQuest runs with multiple replicates per solution enabled, the results that are plotted and exported to CSV are the average of the replicate values. It would be very useful if there was an option under the Advanced settings to use median instead of average. That way, the results wouldn't be skewed by a small number of really large or small values in the replicates. I am working with a model that would greatly benefit from using median in the OptQuest results.
The replication box plots shown in the Experimenter results use median, so it would be more consistent to default to median in the multiple replicate OptQuest results.
4 Comments
jon_abbott
Hello FlexSim developers! Has there been any progress on this idea? Thanks.
jon_abbott
This idea received a lot of upvotes but still hasn't had an answer in over 3.5 years... please consider adding this feature. Thanks!
JordanLJohnson
This feature is now available in version 2022. You can choose the aggregation method for your objectives.
jon_abbott
Thanks @Jordan Johnson! Much appreciated.
