Zone Statistics Dashboard shows no Content
sebastian_hemmannE3JAU
[ FlexSim 23.1.1 ]
Hi, if I take a "Zone Statistic" to a dashboard. Connect it to a Zone in PF and leave the "Statistic" in the Properties on "Content" it doesn´t show any results in the dashboard.
Since it is repeatable I do not share a model.
My workaround so far is, to change the "Statistic" to anything else, let the model run for a while and change it back to Content.
But since it is the default setting, this should not happen!?
JordanLJohnson
Hmm, I fixed a related bug, but I think this is a separate issue. I'll add it to the dev list.
To work around it, you can just pick "Content" when you first make the chart. It feels strange to pick something that is already selected, but it seems to work.
Jordan Johnson
Principal Software Engineer
Thank you @Jordan Johnson , seems as if your workaround works for all 3 different types of the "Zone Statistics".
Matthew_Gillespie
@Sebastian Hemmann This issue has been fixed in 23.0.8 and 23.1.2 released today.
Matthew Gillespie
FlexSim Software Developer
