Write boolean value to global table
chia_lu_t
chia_lu_t
hi every one, I am a new user of FlexSim. In process flow, I want to compare two variables and depend on the conditions like greater or less and then to write boolean value (true or false)(1 or 0) to global table how should I do?
Matthew_Gillespie
You can write to a global table using the Table API. After adding a global table in the toolbox you would use code like the following:
Table("GlobalTable1")[1][1] = variable1 > variable2 ? 1 : 0;
Matthew Gillespie
FlexSim Software Developer
joshua_s
You can do this by using a custom code activity in process flow as shown in the picture below, or using the line of code below.
Table("GlobalTable1")[row][column] = 1
