Write a usage time in a table
oscar_c13
oscar_c13
[ FlexSim 21.2.2 ]
I wanted to be able to write in a table, the time that a processor has been used, but I don´t know what code I have to use in the table to be able to refer to the processing time.
I did this but I don´t know if there is a better way.
ProcessTimeTable.fsm
jose_antonio_mad
Hello @Oscar C13,
You can use the code "getTotalTimeAt". For example:
Object P=Model.find("Processor1");
return P.stats.state().getTotalTimeAt(2);
You can find more examples in the forum: How to get the collecting time of a process flow Sink from its tree ? - FlexSim Community .
I hope I have been helpful.
joerg_vogel_HsH
I have two solutions added. I evaluate the staytime twice: first in Processfinish trigger, second by Process Flow:
Model.time-getentrytime(item) // Trigger value for a new row
Model.time-getentrytime(token.item) // Process Flow for a new row value
Second solution: a label at processor sets a process time
I read this label value. I need a reference to involved processor which I assign in previous event driven source activity to a token label: token.Processor
token.Processor.myCurrentProcessTime // read label value for a new row
You will choose a template in a trigger or in Process Flow for a Custom Code activity
getStaytimeProcessor.fsm
oscar_c13
Thanks, I understand,
but if I put this code in the "Code Editor" it doesn´t work well.
joerg_vogel_HsH
In Global Table Quick Properties you can add a behavior what happens On Reset. I have chosen "delete all rows".
jose_antonio_mad
This codeI posted is the same used by statistic collector. However, you don't use the same code I sent to you (P.stats.state().getTotalTimeAt(2) ), you use P.stats.state().getTotalTimeAt("2") . You use a text, that is the reason why your model does not work.
