Why do all my array values change?
enrique.elizaga
enrique.elizaga
[ FlexSim 18.2.3 ]
I have a Global table with one column that holds array type values.
When I change the value of either one of the array elements, all the arrays in the table change to the same value...even if I change it manually, I can se it before my eyes. Do you know why?
joerg_vogel_HsH
Straight from the manual:
By default, Arrays are passed around as shared references. This means if you set one Array variable to another Array variable, you are setting the variable to a reference to the first Array, not a copy of the first Array. Thus, if you change either variable's referenced Array data, and it will change it for both variables.
FlexScript class reference : array
Description of online manual version 19 applies for your version,too.
If you need independent copies you use the method “clone”.
enrique.elizaga
@Jörg Vogel You are right. I made the mistake of copy-pasting cells in the table to "copy format", when really I was copying the array itself. Instead now I am formatting the cell and assigningi it an TABLE[row][col] = ARRAY.clone(). This way it preserves the integrity of each array.
