One processor pushs to two ItemLists
hayhernandes9
hayhernandes9
[ FlexSim 19.0.0 ]
Hi!
I have two Lists in process flow,List1 and List2 . I create two different ItemLists,and I have two different sources connect to single processor .I want the processor can push two different ItemLists to two different Lists,then set priority of pushing them ,Example I want processor push ItemList1 to List1 first,then push ItemList2 to List2 after that . Is there any possible way to do this?please assist me.
model-ask1.fsm
thanks,
joshua_s
You can do this in the triggers for the processor. This allows you to do several actions in the sequence you desire.
hayhernandes9
How can I set sequence that it has to push to ItemList1 first ,push to ItemList2 second?
joshua_s
the first one does list 1, then the second one does list 2.
joshua_s
This model has your Processor push the items to the lists in the sequence you want, I added a queue because as soon as you sink an item, the list won't have anything to reference.
17851-model-ask1-1.fsm
hayhernandes9
@Joshua S That works very well .Thank you in advance for your help.
