wait idle until to a queue in the 3D Model
savannah_b
savannah_b
[ FlexSim 20.0.9 ]
In my 3D Model there are 320 objects released each day but they get broken into batches that are defined by the capacity of another process (120). That leaves a batch that is only 80 objects. Is there a way in 3D Model to do a "Max Idle Timer" like there is in Process model?
I currently have it using the only 3D Model option in queue: Max Wait Time, but that means it has to wait for a full batch to be completed before sending -which it is not- and that creates an inaccurate run time.
Ideally, the queue would wait until it had a batch of 80 and then start a timer but I wasn't sure how to do that either.
Any suggestions are appreciated.
jonathan_s3
Without looking at your model it would be difficult to determine a solution but you may look at the objects idle state timer in the model tree. You may be able to determine a way to monitor that then.
jason_lightfoot_adsk
You can send a delayed message to the queue when the content reaches 80 - do that on the entry trigger.
Then in the message trigger you could perform the actions you require - releasing flowitems to specific ports etc..based on the conditions when it fires.
Ben_WilsonADSK
Hi @Savannah, was jason.lightfoot's or Jonathan's answer helpful? If so, please click the red "Accept" button on one of their answers. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
savannah_b
Is there a way to have the message pull a specific batch number depending on the day?
The message could set a label which is then used by the pull requirement to only pull a certain batch number. Without seeing exactly what you're trying to do, our answers can only roughly guide you.
