wait for an event by condition
myriam_srdg
Message 1 of 8
myriam_srdg
[ FlexSim 22.1.0 ]
I've created an object process flow, that triggers when a box covers a PE. Based on some conditions, the box stops or sinks. The box resumes when a model variable reaches a threshold. I've managed to resume the object after a time, but I'm don't know how to write a variable-based condition.
Thank you,
Replies (7)
Message 2 of 8
m_rosadini
Hi Myriam,
probably the easiest way is by using a label on the item.
Hope this model can help
support mondragon.fsm
Message 3 of 8
Jeanette_Fullmer
Hello @Myriam Srdg
I wrote two examples of a decide conditionally examining a variable. One is a global variable. The other is a tracked variable.
Varaible_Based_Condition_JF.fsm
Message 4 of 8
myriam_srdg
Thank you both for the examples. I think I didn't express myself correctly or I'm not able to interpret them right. I achieved to make a decision based on a variable. What I'm struggling with if with resuming the item once the condition that made it stop changes. In the example that I upload, what I want to stop the object in the first PE and only resume it when the number of items between the PEs is less that 2.
varaible-based-condition-jf-ms.fsm
Thank you
Message 5 of 8
Jeanette_Fullmer
Hello @Myriam Srdg,
This will work if you use a tracked variable instead of a global variable. The tracked variables can be referenced in a wait for event.
varaible-based-condition-jf-ms_1.fsm
Message 6 of 8
myriam_srdg
Thank you very much! Discovering tracked variables was awesome ))
Message 7 of 8
myriam_srdg
Hello @Jeanette F,
Is there a way to wait until an event (as in the example) but with 2 tracked conditions? I have to decides and I want to resume when one or the other condition is met.
Thank you!
Myriam
Message 8 of 8
Jeanette_Fullmer
Hello @Myriam Srdg,
You would need a wait for event for each variable. In the model provided you can see how I implemented this.
varaible-based-condition-jf-ms-2.fsm
