Using process flow to model assembly
Matthew_Gillespie
Autodesk Autodesk
Matthew_Gillespie
[ FlexSim 18.0.2 ]
I am trying learn how to use process flow to model a assembly work station. I did go through the tutorial, and am able to build smaller models. I am having trouble building logic for the attached model. I am trying to do the following,
A. Operators 1 and 2 will move the pallet from b1 to station 1
  • 1.Operator 1 will install part from q1 to station 1, walk to q2
  • 2.Operator 1 will install part from q2 to station 1, walk to q3
  • 3.Operator 1 will install part from q3 to station 1
In parallel to steps 1, 2 and 3
  • 1.Operator 2 will install part from q4 to station 1, walk to q5
  • 2.Operator 2 will install part from q5 to station 1, walk to q6
  • 3.Operator 2 will install part from q6 to station 1
B. Operators 1 and 2 will move pallet from station 1 to b2 and go back to step A
Is it possible to walk me through how to achieve this using process flow?
station-template.fsm
Matthew Gillespie
FlexSim Software Developer
Matthew_Gillespie
Here's an example of one way to do it.
station-template-mg.fsm
Matthew Gillespie
