Using decide activity to stop simulation based on input value
e_yiing98
e_yiing98
[ FlexSim 21.1.5 ]
0511.fsmHi there,
I am trying to stop the simulation when the input value of Queue8 reached 10, I use decide > conditional decide > Model.find("Queue7").as(Object).stats.input.value==10
But it doesn't work...
Are there any suggestions? Thanks!
SCHamoen
@Emily K If you put a decide in you have to have 2 exits. You currently have only 1 exit on the decide but if the queue content == 10 it should go to exit 2. But there is no exit 2 so it doesn't go anywhere. You can also see that because all your tokens stay in your decide. So simply add a custom code activity and connect it from the decide to this activity and put the code stop(0) in that custom code activity and you should be good to go.
e_yiing98
Thank you Steven for giving suggestion 🙂
But I would like to stop the simulation, when the total input of Queue8 == 10 not current content of Queue8 == 10
Is it correct to use this code?
Model.find("Queue8").as(Object).stats.input.value==10
jason_lightfootVL7B4
That is correct.
e_yiing98
Thank you so much!
