How to Retain Original Array?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I am having array of length 8. Array = [1,2,3,4,5,6,7,8]
After picking 2 from array, I am able to get the remaining part using splice function. [1,3,4,5,6,7,8]
But, it is changing the original array also to the same value.
I have tried to make copy of array which is having reference of original array. But, even in this case it is changing the original value of array.
How can I retain the original array?
Thank you!
moehlmann_fe
If you set a variable to an existing array, the variable is only really a 'reference' to the original array. Any changes are thus directly applied to the original.
To get an independent copy of the array, use '.clone()'.
// This changes the original array
Array nums = originalArray;
nums.splice(...);
// This does not
Array nums = originalArray.clone();
nums.splice(...);
The same is true for tables.
rajankur6494
Thank you @Felix Möhlmann !
