Use parameter to decide when to import from excel
marc_r5
marc_r5
[ FlexSim 22.1.1 ]
I am dealing with a model, meanwhile we are creating a custom db to import the data.
To make tests I use also an excel model to import data.
For the db import, I create a parameter and a custom code so I can decide if I import from the db or not, with a simple conditional.
Is something similar for the excel import?
I see that in the excel import/export menu there is a post import code option, but I would like to be able to do it in custom codes and using parameter, specially for the import decision.
Thanks!
jose_antonio_mad
Hello @Marc R5,
You can use a parameter condition (f.ex.: if....else...) and if the condition is tue,use the following code to import excel files:
excelmultitableimport()
I hope I have been helpful.
