Use AGV to Operate Processor when Use AGV Process Flow
IEThai
IEThai
[ FlexSim 20.2.3 ]
Hi I try to use AGV Process Flow to transport flowitem
but i have a problem when i want to use AGV for operate on processor
for example when AGV1 transport flowitem to processor. I want to use AGV1 to operate the processor like a use operator and when AGV2 transport flowitem to processor I want use AGV2 to operate the processor
Please help me to fix the problem
AGV Work.fsm
joerg_vogel_HsH
your request is not a part of the AGV template. you give the taskexecuter an utilize task to keep him at the processor and free the operator on process finish event of the processor.
IEThai
sorry I'm new user. I don't know how to give utilize task when him at the processor. Can you example how to fix it in my attached file?
thank you
allister_wilson
What is the reasoning behind using the AGV process flow template as opposed to standard transport / call operator behaviour?
If you were using standard behaviour, you could just use the existing Tagged Resource option in the transport and use operator fields to ensure the same AGV performs both transport and process for a given item.
IEThai
Sorry for late reply , I try to use AGV process flow template because i think it easy for control taskexecutor such a backhual , So i try to use the template for use the AGV as a operator , when AGV pick the flowitem to processor the processor will use the AGV for operate
Please advise
allister_wilson
If I were you, I'd use standard transport / call operator behaviour instead of the AGV template in that case.
You'd need to make some pretty significant changes to the AGV template in order to make it do what you want, it's simply not designed with call operator behaviour in mind (since AGVs are generally only used for transporting things) and doesn't have any built-in support for it.
IEThai
Thank you very much for advise
