Unload pallet using Task Executer
nikhil_rane9NJAU
nikhil_rane9NJAU
[ FlexSim 22.2.0 ]
I am building model for just time concept for assembly line, in which i am have to deliver loaded pallet at assembly station and pick up the empty pallet from station and unload that pallet to super market.
I am able to compete model using process flow. But I am not able to unload the pallet to supermarket once the task executer complete the look . Can you help
Model Name ( JIT Simulation 2 Part )
kavika_faleumu
Hey @Nikhil Rane, the reason you're getting an error is because when your TaskExecuter1 reaches the EmptyCart queue, your Process Flow moves the token from Travel to Unload.
That Unload is expecting a "token.item" to put into the queue. However, the token going into it doesn't have an "item" label.
Make sure that that activity sets the item label on the token when the TaskExecuter1 picks it up.
