union of parts
union of parts
bsabrunosouza1
Message 1 of 18
union of parts
bsabrunosouza1
[ FlexSim 23.1.3 ]
Hey guys! Hope all is well with you.
Well, I'm using the Combiner that needs to join 1 unit from Queue 1 + 1 unit from Queue 2 so that the Product is sent to the output, but as you can see in the image it's only considering Port 2. How can I solve it?
Replies (17)
Message 2 of 18
joerg_vogel_HsH
Because port one is a default port to collect a container item. One item is always entering through port one. And it it only one item.
Message 3 of 18
bsabrunosouza1
How can I fix this?
Message 4 of 18
joerg_vogel_HsH
@Bruno Almeida, what do you want to fix? It is a default permanent active behavior. First item of port 1 is needed for a combiner. And it the only item a combiner can work with from input port one!
Edit: perhaps it is getting more obvious, if you read about this object in the reference manual.
Message 5 of 18
bsabrunosouza1
The combiner needs to put together an item from Row 1 + an item from Row 2. So is that right?
Message 6 of 18
bsabrunosouza1
That is, it needs to be 1 package from Queue 1 + 1 packet from Queue 2 => together they give the output.
Message 7 of 18
joerg_vogel_HsH
No, @Bruno Almeida ! A combiner receives independently from his components list always one item and only one item from input port number 1. Then he can combine to this first item other items from input port 2 or higher port numbers from the components list together in different combine modes.
Message 8 of 18
julie_weller
Hi @Bruno Almeida! Like Joerg said, the combiner automatically takes an item from port 1 (it has to be a pallet or a tote) but if you want to do something different there are lots of examples on this site on how to customize combining like this one:
https://answers.flexsim.com/articles/133869/example-model-opportunistic-combiner-process-no-po.html
If you don't want to put something on a pallet or a tote it might be worth researching it on this site. There are lots of people who have asked the same question.
Message 9 of 18
joerg_vogel_HsH
@Julie Weller, I am sorry, but first item can be a tote and pallet, because they support by default a packaging node function. But any item is allowed to enter a combiner by port one. It needs some effort to place next items inside a standard first item.
Message 10 of 18
julie_weller
That's fair, it's just not recommended
Message 11 of 18
bsabrunosouza1
When running the simulation, the ones after the queue are not being merged but placed separately.
Message 12 of 18
jason_lightfoot_adsk
You're going to have to supply more information than that picture. The model or pictures of how the model is now configured.
Message 13 of 18
joerg_vogel_HsH
Message 14 of 18
bsabrunosouza1
@Jason Lightfoot
Follow model. Model.fsm
Message 15 of 18
bsabrunosouza1
I ended up making some changes.
Message 16 of 18
joerg_vogel_HsH
@Bruno Almeida, your problem is not your components list!
You have to send items from your processors "reta#" to one of your queues depending on the type pallet or box. You could try to identify the shapeindex.
I go by the item name "Box" or "Pallet". Output function Send to Port needs a Port By Case evaluating item.name and cases by "Box" and "Pallet" to divert items to the right queue. Then your model starts to work in a simplified way.
Please let it run a bit longer. Then you can also think about sending pallets to different combiners depending on item label name "Esquerda" in Queue "Direita".
Message 17 of 18
carter-walch
Hi @Bruno Almeida, was one of Julie Weller's or Joerg Vogel's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
Message 18 of 18
natalie_white
