Unable to pull first item from list
giovanni_ceroni2
giovanni_ceroni2
[ FlexSim 25.0.2 ]
I have a process that creates pallets in specific locations and boxes in each pallet according to gllobal tables. Then it put every token per line of order in a list of orders. the process should pull the first order and copy its OrderID, but it doesn't work as intended the value is null and says no path to firstPulled.
QUESTION LIST.fsm
Paula_LG
The problem here is that the firstPulled token is destroyed immediately after being pulled from the list (Finish activity). It can be solved by adding a breathe activity between Push to List and Finish, so that when you try to copy the orderID, the token still exists:
I hope it helps!
question-list.fsm
giovanni_ceroni2
Thank you very much, now it writes the orderID.
I tried connecting the paths i disconnected to test these and now it says error in the travel task. Why?
question-list.fsm
Paula_LG
You're asking the operator to travel to an object named "AJSHB" (token.CodArticolo), which does not exist.
giovanni_ceroni2
Yes, thank you. Now it works but only for the first line of order. The next line is null. Why is it? i don't understand
question-list.fsm
Paula_LG
The second time the sub flow is run, the pulled tokens don't exist anymore. If you want to use any information on those tokens for your logic, you need to gather it right after you pull them, before they are destroyed. You can save it on a label, just as you did with the orderID.
question-list.fsm
giovanni_ceroni2
Thank you very much!!
now it works
