turntable issue
turntable issue
Pooja_inde
turntable issue
Pooja_inde
Dear Team,
I have identified some errors in the turntable process flow. Could you please review and help resolve these issues?
Please find attached the model for your reference.
Thank you for your support.
FelixMoehlmann
 It seems you copied the Process Flow from Jason's answer in this other post or some other model that got it from there.
- You apparently copied the Process Flow into the "Basic Processor" template without removing the default activities. The old Source activity is causing error messages.
- The Process Flow is designed to work with a BasicFR object. You placed a visual shape that does not port-connections and does not have Entry/Exit events. Replace it with the correct object type (found in "Advanced" tab of library).
- Remove the conveyor that currently links the other two conveyors together and instead connect them through the BasicFR.
- Resample the entry and exit events and assign the entering item to the "item" label in the Wait For Entry activity.
- Adjust the coordinates in the Change Visual activity to fit the size of the BasicFR.
