Triggering wait for event in process flow using sendmessage()
rhramac
Message 1 of 13
rhramac
[ FlexSim 21.2.4 ]
Is there a way to trigger wait for event activity in process flow from using sendmessage()?
sendmsg.fsm
Replies (12)
Message 2 of 13
joerg_vogel_HsH
I think, it is more likely the on receive message event, that you can evaluate.
Message 3 of 13
jason_lightfootVL7B4
In you case you can just detect that a token enters/exits the activity: "Custom Code- Send message"
Message 4 of 13
rhramac
Hi Jason, Thanks for your response. I asked this as part of bigger model where I use a customized library in flexsim. I add instruction to travel, and then instruction to send message, so that the message is triggered after travel is completed. So detecting token entry exit to custom code will not help.
Message 5 of 13
rhramac
Hi Joerg, can you explain it a bit?
Message 6 of 13
The OnMessage event is common on the objects and a wait for event activity, when you sample an object that has the event, will offer OnMessage as the triggering event. This is not the sending of the message but the receiving.
Message 7 of 13
rhramac
So can a wait for event activity listen to itself, if there is a message being passed to it or can it listen to only 3D objects
Message 8 of 13
Doesn't look like it from either the dropdown list you get when you sample it, or a simple test.
I think pushing to and pulling from lists are a much better option for synchronization like this - so much more transparent.
Message 9 of 13
rhramac
I was able to send message to queue and use wait for event to listen to it. Since the send message has only double parameter. I send passed an object with all details in the fromObject argument. Thanks to @Logan Gold for walking me through the process.
Message 10 of 13
Glad you were able to articulate what you were looking for with Logan. You're still not detecting the message sending event unless it's sent and received in zero time. If it's a delayed message then you'll not be able to detect the sending event
Message 11 of 13
rhramac
In my case I am sending regular sendmessage() and not delayed. Can you please elaborate why it would not work for a delayed message? Curious.
Message 12 of 13
You're detecting the receiving of the message, not the sending of it. So if the message is delayed by n seconds you're not going to know when it was sent unless you also pass that as a parameter.
Message 13 of 13
rhramac
Makes sense. Thanks for the explanation.
