A efficient method for reflow process model
che_wei_c
che_wei_c
[ FlexSim 20.1.3 ]
I build a simple model for a re-flow process. However, if I wanna build a large scale re-flow process model, is there a efficient way to construct the Flexsim model that refering a global table that based on its step, or others smarter approach.
Thanks for your kindly reponse.
Best regards,
Wade
Re-flow process model.fsm
moehlmann_fe
You can use the "Start Activity Named" or "Start Activity By Case" options in the Run Sub Flow activity to send the token to different subflows depending on a token label. That token label can then just iterate through one row of the steps table. The type label determines which row and the column number is incremented after each subflow run. Inbetween, a Decide activity checks whether there are still more columns and whether the value in the next cell is not 0 (no more tasks). In one of those conditions is not fulfilled the token is send to the sink.
re-flow-process-model-fm.fsm
che_wei_c
Hi Felix,
Thank you so much for your response.
Wade
