Transporter's items not stacked
marco_baccalaro
marco_baccalaro
[ FlexSim 18.0.2 ]
How can I avoid the Transporter to stack flowitems?
  • Changing the items location On Entry doesn't work on z because a kinematic is overwriting their z position
  • Trying to overwrite the z On Draw doesn't work too
joerg_vogel_HsH
You can transfer the items into the drawsurrogate node.
In the OnLoad trigger put this code:
moveobject(item,current.attrs.drawsurrogate.find("Truck/Forks"));
item.location = Vec3(0,0,0);
You have to adjust the location of each loaded item to your wishes.
marco_baccalaro
Thanks Jörg, it worked!
