Token not move
Token not move
Jonathan_Huang
Message 1 of 12
Token not move
Jonathan_Huang
[ FlexSim 23.1.2 ]
Hi Everyone
In my attached model
Rhino 5 20240412.fsm
Please increase speed and run the model to 8:44 AM
Then help me to see the Frame OP_T3 in Process flow
The token for wait for event cannot move to Release activity
So the task cannot be reset to run the next task sequence
Maybe I made some mistake
Please help me to see the problem
I tried long time but can't find out
Thanks and best regards
Replies (11)
Message 2 of 12
FelixMoehlmann
The logic is correct. Queue17, which T3 feeds into has a maximum content of 1 and there seems to be no logic in place that moves items out of it. So T3 is simply blocked and can't release the item.
I also don't understand the purpose of the Process Flow. If T3 is empty, the item is moved there through a port connection in the 3d model. Only if T3 is busy is the item send to a queue, which then puts the item onto a list and the Process Flow moves the item into T3 anyway, ignoring that it could not receive the item through the port connection.
Message 3 of 12
Jonathan_Huang
Hi Mr Felix
Thank you for instruction
I deleted the port connection to T3 in 3D model and then set Queue17 maximum content greater than 1 and the token was moved.
Message 4 of 12
Jonathan_Huang
I am sorry to reopen this issue but when I set T3 and T3_2 process time =20s. The token was pass through waiting for event activity. But when I changed it to 100s. The token cannot move.
Please help me
Rhino 5 20240413 ver1 NG.fsm
Message 5 of 12
Jonathan_Huang
You can check in this process flow in the model
Message 6 of 12
Jonathan_Huang
You can move related objects to another place to make it easier to see the connection in 3D model
Message 7 of 12
Jonathan_Huang
This model is easy to see
Thank you!rhino-5-20240415 NG ver.fsm
Message 8 of 12
FelixMoehlmann
Eventually Queue24 is full and the blockage starts to propagate through the model backwards until all process are blocked.
Other than that I don't see any issue though.
Message 9 of 12
Jonathan_Huang
It was because T3 process time = 20s. If change it to 100s. It will not move. Please try to set T3, T3_2 process time to 100s and run the model
Thank you!
Message 10 of 12
FelixMoehlmann
The child tokens (the ones becoming stuck) currently read all labels from the parent token. So when the parent pulls a new item and overwrites the "item" label, the first child will now wait until that new item exits T3. This then also happens for the second token: The item reference changes before the process is done.
In "Create Tokens", copy the labels to the created token, so they read their own rather than the parent's "item" label.
Message 11 of 12
Jonathan_Huang
Hi Mr Felix. I followed your instruction. But it was not changed
Message 12 of 12
Jonathan_Huang
Sorry Mr Felix
It worked. Thank you so much!
