TimeTableChangeUsingDashboard?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I want to create dashboard for user interaction where timetable working hours can be changed.
Is there anyway to do it?
FlexibleTimeTableUsingDashboard.fsm
Thank you!
jason_lightfoot_adsk
Do you need the full user inferface of the date-based view or something simpler? For example you can link to the timetable table using a simple table widget:
You just need to refer to the Timetables>variables/table node in the link.
But this is very basic - and potentially could cause problems if a user messes something up. You might be better to write to the table in the background based on some other simplified input.
Jeanette_Fullmer
Hi @Ankur A3,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
