Importing c++ from Excel
julio_r
julio_r
[ FlexSim 22.0.4 ]
I am doing a simple Excel import to a Global table and I get this message:
I do not have anything diferent than number and strings in the Excel, and I do not want to complile the model. Why is this showing and can it generate any errors in my model?
JordanLJohnson
My guess is that the Data Distinction option you're using is determining that C++ is present.
If you really do only have numbers and text in Excel, then you can use the Values Only option for Data Distinction.
Jordan Johnson
Principal Software Engineer
julio_r
Thank you, I am using just numbers and text so I will use the Value only option (also it is a big file so it will help with speed)
