Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Time table does not work after updating it's members by code.
kraus_martin10
kraus_martin10
I would like to ask regarding the Time Table functionality. Since I assigned specific objects to a created Time Table manually, the Time Table works perfectly. During the simulation run I have one trigger that changes the Time Table's members. After this change it does not affect anything. I guess there should be some command for updating the functionality.
Can someone help please?
Thank you.
Martin
FelixMoehlmann
Dynamically adding/removing members of a time table during a model run is not supported. What you can do instead is to add a condition to the down function that prevents the object from actually being stopped based on a label (for example). By changing the value of the label you can then effectively remove objects from the time table (exclude them from being stopped in future down times).
kraus_martin10
Thank you for the information. Can you please give me an example as I am not sure how it should be implemented.
FelixMoehlmann
In the attached model both operators follow a time table with a pattern of 15mins downtime followed by 15mins of uptime. At 09:00 the Process Flow switches the label on Operator1. This then causes the downfunction to skip that object and Operator1 stays active.
kraus_martin10
Thank you! I works perfectly.
