The output by hour charts in my dashboard are not working in experimenter.
walter_h2
walter_h2
[ FlexSim 22.0.1 ]
I receive an except about the columns having the same name. I see no data in the experimenter charts. The ouptut by hour chart works fine when running the model. I noticed that statistics collector has multiple "throughput" columns. I am using version 22.0.1
JordanLJohnson
Yes, this is a confirmed bug. The bug is the double column name, as you have found. For now, the workaround is to install the chart, and rename the second column to Object. Hopefully, we'll get this fixed soon.
Jordan Johnson
Principal Software Engineer
ryan_c10
Hi @Walter H2, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
