The global table is not updating correctly with control points
vothan_salomao
Message 1 of 8
vothan_salomao
[ FlexSim 23.2.0 ]
Hello!!AGV GlobalTable.fsm
I'm trying to fill in two columns of the global table with the following information:
In the CP column, I want the column to update in real-time with the information from destination.CP.
In the LastCP column, I want the column to update in real-time with the information from the last CP that the AGV passed, I'm using recentCP.
However, when running the code, both columns still have the same information. Could someone help me by telling me what's wrong with my code and how I could fix it?
https://prnt.sc/0hQawjGVDalY
Replies (7)
Message 2 of 8
jason_lightfootVL7B4
The exception message tells you exactly the problem - the token doesn't have the label 'destination'. You can verify this by putting a breakpoint in your code.
and then click on the token when it fires the code.
When an exception occurs the rest of the code is not executed.
Message 3 of 8
vothan_salomao
Hello @Jason Lightfoot. thanks for the answer
My question is specific about globalTable. How a i can modify the columns LastCP and CP in real time?
The value Token. destination i understand the problem. But dont understand how modify the columns CP and LastCP, what is problem with my code? global-table.png
Message 4 of 8
Put breakpoints on lines 25 and 44 - you will see that your code is updating the table correctly up to the point where the lack of the label 'destination' causes the exception.
Of course these triggers make the code look complicated. In fact it could just be a line for each:
Table("AGVs")[current.name]["cp"]=agv.destinationCP;
Table("AGVs")[current.name]["lastCP"]=agv.recentCP;
Message 5 of 8
vothan_salomao
The problem is, my global table dont update with correct value of CP and LastCP1695668583159.png
Message 6 of 8
Try putting this on the draw code of the AGV if you want a realtime view. The same could be done with a list and field expressions:
AGV agv=AGV(current);
Table t=Table("AGVs");
t[current.name]["cp"]=agv.destinationCP;
t[current.name]["lastCP"]=agv.recentCP;
t[current.name]["destination"]=agv.finalDestinationCP;
Object dest=agv.finalDestinationCP;
if (dest)
    t[current.name]["Distance"]=distancetotravel(current,dest);
Message 7 of 8
vothan_salomao
Hello @Jason Lightfoot , thank you very much for the help. I conducted some tests and managed to solve the problem by placing the code in the "Trigger On AGV Allocate" of the AGVs
Message 8 of 8
jonah_kendellR47TC
Hi @Vothan Salomão, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
