Storage Object Capacity
maryamh11
maryamh11
[ FlexSim 23.2.0 ]
Regarding this post, how can I reference a specific object within the storage system, such as Rack1? https://answers.flexsim.com/questions/145983/capacity-of-the-storage-system.html
var storageObjects=Storage.system.storageObjects;
jason_lightfoot_adsk
You can either find it in the model:
Model.find("Rack1");
or in the list of storageobject if you know the index:
Storage.system.storageObjects[2];
Where are you trying to use it?
The example already splits the capacity out by storage object and item:
generateRackCapacities.fsm
maryamh11
I have a very small items (similar to TestTube) and I want to figure out how many of them can fit in a specific type of rack or storage unit. The problem is, my code takes forever to count them in each storage unit, and it often crashes. I have more than 250 storage objects and I do not want to consider all of them. Is there a way to make my code just look at one storage unit instead of going through all of them? How do I find an index of a storage object?
Use boxes of tubes and multiply by the quantity in a box. You won't be storing millions in the racks individually (I hope)
maryamh11
Do you mean there is no way to reference to a storage object individually?
I can not do boxing since that also going to check for every storage objects, i want to check just for one storage item type?
In the following model I changed the functon generateRackCapacities to accept an array of flowitems and optionally an array of racks. So the syntax in a script window would be like this:
Object rack1=Model.find("FloorStorage1");
Object rack2=Model.find("Rack2");
generateRackCapacities(["Tote","Box","Pallet"],[rack1,rack2]);
which gives:
generateRackCapacities2.fsm
maryamh11
perfect, thanks!
