Task sequence as Label
selvantamil674
selvantamil674
[ FlexSim 23.1.1 ]
I have a list of activites for each robots, can i give it as Label for each robots through global table
joerg_vogel_HsH
@Tamilselvan, a label is a node. You can put anything into a node even subnodes of tasks. You can put a reference of a tasksequence into such a node. But it would be a good idea to attach an example model to your question. Then it is easier to understand what you want to do.
julie_weller
@Tamilselvan depending on how complicated the differences are you could make an object process flow for all the robots and then click on specific instances to specialize specific robots. Here are two links that can explain it a bit more:
https://docs.flexsim.com/en/23.2/ModelLogic/ProcessFlowBasics/TypesOfProcessFlows/TypesOfProcessFlow...
https://docs.flexsim.com/en/23.2/Tutorials/ProcessFlow/Tutorial4Instances/4-3Instances/4-3Instances....
julie_weller
Hi @Tamilselvan,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
selvantamil674
Hi @Julie Weller
its working fine, thanks for your help. Sorry for the delayed response.
jason_lightfoot_adsk
What did you end up implementing?
