System Console opens on launch FlexSim 2024 Update 2
DiegoAvila1
DiegoAvila1
[ FlexSim 24.2.2 ]
Whenever I start FlexSim 2024 Update 2 all it opens is the system console with:
exception: FlexScript exception: Method find() called on node that does not exist at MAIN:/project/events/OnStartApp/read user prefs at line 17
exception: FlexScript exception: Invalid node passed to FlexSim::set at MAIN:/project/events/OnStartApp/initialize environment at line 45
exception: FlexScript exception: Invalid node passed to FlexSim::set at MAIN:/project/events/OnStartApp/initiate autosave at line 10
I have tried opening new files and old ones and neither works.
FelixMoehlmann
Those exceptions point to the "environment" node in the view tree somehow missing. All I can do is suggest to try reinstalling FlexSim.
DiegoAvila1
I uninstall FlexSim but it continued the same. The solution that worked was delleting FlexSim´s saved settings (the prefst.file).
DiegoAvila1
NICXON_NIHUA
Como hago eso??? tengo el mismo problema amigo
maryo8428
Community Visitor
Community Visitor
  1. Cierra FlexSim completamente.
  2. Abre el Explorador de archivos y escribe esto en la barra de dirección:
    %AppData%\FlexSim
  3. Busca una carpeta llamada algo como:
    FlexSim 2023 FlexSim 2022 o similar según tu versión
  4. Renómbrala, por ejemplo, a:
    FlexSim 2023_backup
  5. Vuelve a abrir FlexSim.
    → El programa creará una nueva carpeta limpia de preferencias.
Si el error desaparece, ya estaba dañado el archivo de configuración y se solucionó
