Syntax for PartitionID in List.entries()
clairekruppGhafari
clairekruppGhafari
[ FlexSim 22.2.2 ]
I am trying to grab the token in a list partition so that I can get the current value of the label "NumSheets". (It would also work if I can just grab the value of NumSheets directly from the list.)
I am using list.entries() but no matter what I put inside the () (nothing, a number, or a string) it tells me that the list is empty.
Here is my test code and the status of the list when I am executing the script:
I have tried entries(), entries(1), and entries("nsLEPE1"), but it always comes back with len of 0.
What is the proper syntax?
clairekruppGhafari
BTW I made it a Global List, so that I could use list.entries().
JordanLJohnson
I wonder if the partition is a node value, so you need to use
WIPList.entries(Model.find("nsLEPE1"))
If the partition value is a string value, then the screenshot you shared is missing a "1" on the end of "nsLEPE1".
Jordan Johnson
Principal Software Engineer
clairekruppGhafari
Thanks @Jordan Johnson , the "Model.find" did not work, but the typo correction did!
Hopefully it will still work when I pass in "token.ProcessName" instead of the text string.
But then in line 7
Object WIPtoken = WIPlist.entries("nsLEPE1")[1].value;
gives an "Invalid down cast" error.
I copied the placement of the [1] from the user manual, but maybe something else is needed?
Or is the value on the list (a token) not an Object?
clairekruppGhafari
I changed the Object to Token and now line 7 works, but
int numsheets = WIPtoken.NumSheets;
is bombing out with no error message...
I had to use
int numsheets = WIPtoken.labels["NumSheets"].evaluate();
So, for anyone following this, the correct syntax is
List WIPlist = List("List: Pallets at nsLEPE");
int len = WIPlist.entries("nsLEPE1").length;
if (len>0){
    Token WIPtoken = WIPlist.entries("nsLEPE1")[1].value;
    int numshts = WIPtoken.labels["NumSheets"].evaluate();
    return numshts;
JordanLJohnson
Use "Token" instead of "Object"
Token WIPToken = WIPlist.entries("nsLEPE1")[1].value;
The values on the list are tokens rather than objects. You can tell because the value field shows "instance" and "id", which it only does for tokens.
Jordan Johnson
