- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working with a 5-workstation assembly line. Each workstation follows a different statistical distribution; Gamma, Normal, 3-parameter weibull, Largest extreme value and Smallest extreme value (which by the way I can't find in the statistical distributions in FlexSim).
The thing is, I only understand the parameters of the Normal distribution (Mean, Standard Deviation). But I have no clue of the rest of the parameters for the other distributions. Parameters are usually: Location, Scale, and Stream.
Can I get any help, please ? What is meant by each parameter, and what are the expected values to be entered ??
And, what can be the alternative for "Largest extreme value" and "Smallest extreme value" distributions ??
Thank you so much for your time and efforts.
Best Regards,
Gasser Yassen
