Staff not moving during their shift
amyhyolee
Message 1 of 15
amyhyolee
[ FlexSim 21.2.4 ]
I've inputted the staff's work schedules and set them to work during their working hours, but most of the staff aren't working.
The model starts at 00:00, and patients start arriving at 5:30.
The staff who work until 6:30 are transferring patients, but those scheduled to work after that aren't transferring patients.
I'm not sure where the error is occurring. I'd really appreciate your help.
practice_v8.1.fsm
Replies (14)
Message 2 of 15
patrickABAWF
I think nobody does anything because there is no patient on List:WaitingPatients and so the tokens wait at the PullFromList.
I don't see anyplace where the patients are pushed to the list.
You need a PushToList for the patients to be on the list.
Message 3 of 15
amyhyolee
@Patrick Cloutier , PushToList is in the Patien Flows.
Do you know what else is making staff not move during their shift?
Message 4 of 15
patrickABAWF
At 6:00, for example, all the staff are in State: OffSchedule.
The red square indicate they are stopped and the state is OffSchedule:
And if I look at Staff8, for example, he is not scheduled to work until 9:
So the problem seems to be your schedules. The red is when they don't work.
Message 5 of 15
amyhyolee
@Patrick Cloutier ,
As you said, I specified the working hours for the staff. So, each staff member has different working hours. Some work at 6 AM, some at 9:30 AM. However, the problem is that these staff members aren't transferring during their shifts. How can I make staff members transfer patients during their shifts?
Message 6 of 15
patrickABAWF
From what I could see, at 6:00, they were all Offshedule.
Give me an example of a staff (which one) doesn't work when he should according to his schedule and tell me at what time. If he has a red square around him, it's because his timetable says he is off.
Message 7 of 15
amyhyolee
@Patrick Cloutier ,
As seen in the image above, Tech 9 is on duty at 6:31AM (23487), but Tech9 is not transferring.
Message 8 of 15
patrickABAWF
From what I understand, your Staff Process Flow only creates 2 tokens so it can only acquire 2 staff and so only 2 staff at a time are doing something.
Either you need to create more tokens or you rethink the Process Flow so that it creates a token whenever there is a need for a staff.
Message 9 of 15
amyhyolee
@Patrick Cloutier ,
Thank you for your answer. Is there a easy way to fix this problem? I not sure why it's creating only 2 token.
Message 10 of 15
patrickABAWF
The Source only creates 2 tokens. Each token acquires 1 Staff so only 2 staff can be acquired at any given time.
I assume by your question that you didn't create that processflow. If that's the case, I suggest you do the ProcessFlow Tutorials in Help/UserManual.
Message 11 of 15
amyhyolee
@Patrick Cloutier, Thank you for your answer!!
Message 12 of 15
amyhyolee
@Patrick Cloutier , If I change the Quantity to 27(total staff number), all the staff transfers patients. However, they are ignoring their schedule time. Do you know why they are ignoring their time table schedule?
Message 13 of 15
patrickABAWF
I’m away without my computer so I can’t look at the model.
Maybe there are no more patients to treat.
Message 14 of 15
priyankasgoudar33
Hi @Amy, change the schedule source timing to 1 and check, has you have given 0 the model is somehow trying to execute token before the timetable and not able to execute the timetable.
Message 15 of 15
amyhyolee
@mary Thank you so much! It works!!
