Specific Code Snippet command for Flexim 2016
vincenzo_dm
vincenzo_dm
[ FlexSim (other) ]
image1.pngHi, I wanted to know the similar Code Snippet command "ts.first.destroy ()" (destroy the first activity for the Transporter) running for Flexsim 2016 version 16.0.1. Thank you!
pkaruppasamy92
Hi Vincenzo,
Try this "destroyobject(rank(ts,1))".
Regards
Karuppasamy
joerg_vogel_HsH
You can change the tasktype of a Tasksequence instead of deleting the task. The tasktype tag hasn't got any influence on the taskexecuter.
changetask(ts,1,TASKTYPE_TAG);
logan_gold
To answer your original question, you can do something like this (which will do the same thing that Karuppasamy Pitchai's code does):
destroyobject(first(ts));
However, it sounds like you are wanting to change how the Transporter is handling its offset travel as part of the unload task. If you would like more help on how to make these changes, please post a new question.
