Solving Property "value" accessed on invalid node and Activity is not shown
jouky_d
Message 1 of 10
jouky_d
[ FlexSim 23.1.2 ]
Hello everyone,
FlexSim gave me this exception:
FlexScript exception: Property "value" accessed on invalid node. at VIEW:/active/MainPanel/BackPanel/SplitterXPane/ToolTabPane~2/TabControl/QuickProperties/ToolPanel/ActivityProperties/Activity Properties/ActivityPropsTemplate~5>eventfunctions/showPanel
I tried to restart the Default Workspace, but it did not work for me.
One of the consequences of this exception is that I couldn't edit an activity (not in its icon or in Quick Properties).
When I close the Quick Properties the exception stopped appering, however I could not edit the properties of the bugged activity.
The solution I found is to split the set of activities (A,B,C,D,E) into (A,B,C) -> (D,E) (assuming D is the wrong activity). That worked for me.
Replies (9)
Message 2 of 10
jouky_d
Okay, sometimes works sometimes not. Sometimes when I create an activity I cannot delete it.
Message 3 of 10
jouky_d
The bugged activities are all Run Subflows.
Message 4 of 10
jason_lightfootVL7B4
We'd need to see your model to understand what's happening.
Message 5 of 10
jouky_d
I cannot send it. But don't worry, I will do it again...
Message 6 of 10
A video would also help us to understand what you're experiencing. You can toggle the post to private if that helps.
Message 7 of 10
julie_weller
Hi @Jouky D,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
Message 8 of 10
jouky_d
I did the model again (from the last good version). Thank you!
Message 9 of 10
jouky_d
Recommendation: Increment save the model. I restart from the last saved model.
Message 10 of 10
jouky_d
I don't know why, I cannot accept any answer.
