Can I add a AGV type in AGV Network Properties in FlexScript?
jkhedekar
jkhedekar
[ FlexSim 23.0.8 ]
I want to automate the repetitive process of creating a AGV network properties by using the script that creates a new AGV network type and sets acceleration and stuff through it.
Thanks.
jason_lightfootVL7B4
You'll need something like this:
Object agvNav=Model.find("AGVNetwork");
treenode newAGVType = function_s(agvNav, "addAGVType");
applicationcommand("notifydoclistenersoncustomaction", "AGVNetwork::onAGVTypesChange");
Table speeds=Table(newAGVType.subnodes["speeds"]);
speeds["Acceleration"]["Empty"]=0.5;
setsdtvalue(newAGVType,"idleAmps",0.5);
jkhedekar
How can I tick attach load as trailers with this script?
setsdtvalue(newAGVType,"trailerAttachRule",1)
You can also access it as a subnode of newAGVType node.
These are the sdt/subnode names:
jkhedekar
For future purposes, how can I know the subnode names?
Explore the tree of the newAGVType node - it will be under the variable agvTypes. These values could change in the future. They could be given access via the AGV API removing the need to use function_s / set node values.
jkhedekar
Thank you!
