Software version downgrade
farah_najihah_a
farah_najihah_a
[ FlexSim 22.1.1 ]
Modified test model trial 1 test lagi dan lagi.fsm
Hi, I have a model with version 2022. But the license has ended. and now I have the software with version 2019. How can I open the model from 2022 in the 2019 version? is there any converter? or can anyone help to convert it to 2019? 😞
I attached the model which I needed to convert to 2019 if anyone could help with it.
Thank you in advance!
joerg_vogel_HsH
You cannot downgrade. And any chance to get support for outdated versions here at this site is very unlikely. It is better idea to contact your distributors of your region to discuss available licenses contracts.
farah_najihah_a
oh no, seriously? anyway thank you for your answer! will try contacting them though.
jason_lightfoot_adsk
No only is it not normally possible, but you've used templates which are not even supported in the earlier versions.
You could script something to read the attributes of objects and recreate the model from the 'scraped' data in another script, but by the time you've done that you would have been able to rebuild the model in the earlier version. Best get the upgrade if you can.
