Simulating a processor/machine with multiple pallets
kshitij
kshitij
[ FlexSim 24.2.2 ]
I want to simulate a machine with 2 pallets, each pallet takes 2 parts. Once we load 2 parts on a pallet, we can start the machining on that machine/pallet. While the machining is going on we can load 2 more parts on the 2nd pallet. Once 1st pallet work is completed, we can immediately start the 2nd pallet machining.
Also make sure that part number on a pallet is same for the 2 parts loaded on to the pallet. I.e. we always load same type of part on a pallet.
Can you help me in simulating the above scenario?
moehlmann_fe
Sounds like that could be modeled with a combiners leading into a processor. The combiner can use a custom Pull Requirement and trigger function to only allow items of the same type on a pallet.
same-type-combiner.fsm
