Paula's statistics collector only measures the content at the slot level. As soon as an item enters the slot, the slot is 'full' regardless of how much space the item actually takes up.
If all items have the same size, you can manually calculate the maximum capacity of a rack and write that number to a label. This label is then used by the statistics collector to calculate the fill level.
Alternatively, you go by volume, where you compare the total volume of items in the rack with the total available volume.
Both approaches are demonstrated in the attached model.
231-statistics-warehouse-usage-fm.fsm
